Old 02-22-2012, 04:58 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Great work on the diagram. Does anyone know if it applies to Jtrucks?
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 07-01-2015, 10:31 AM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Just to update this thread, and I have moved it to the electrical archives.
My 82 Cherokee came with the trailer towing package, and a 7 pin factory trailer plug.
As far as I can tell, when you have the trailer package with the little black box of 4 relays, there is no way to just add a 4-pin flat connector. The lights will work, the turn signals will work, but brake lights on the trailer won't light.
You need to either go thru the factory 7 pin plug using a flat 4-pin adaptor, or you have to add relays like Tony mentioned. I went thru my box and made sure all the relays worked, and used an adaptor.
You must have the 12 gauge bullet connectors, one in and one out, hooked to a hot source. Otherwise, you will hear the relays working, but nothing will come out of the 7 pin plug…. (that was my trouble)
Ristow's Bunker
Old 07-01-2015, 10:32 AM
Strode's Avatar
1st Chair, Cowbell
I read where somebody posted that the J-trucks were different. I have no source on that.
Ristow's Bunker
Driveshaft question. Fab work learfxr General FSJ Tech 0 11-29-2006 06:45 PM
Trailer hitch part number Question badaboom General FSJ Tech 7 10-22-2005 02:47 PM
Question for vacuum schematic gurus Panoscopic General FSJ Tech 7 02-21-2004 04:41 AM
Body work...GEM-A question for ya trickc General FSJ Tech 2 06-28-2002 01:01 AM
7-pole trailer wiring: relays needed? Bob Barry General FSJ Tech 2 11-01-2001 05:17 PM
