Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 10-19-2020, 02:25 PM
JSSmall's Avatar
JSSmall JSSmall is offline
Air cleaner assembly for 2bbl 327 Vigilante
I've got a '65 Wagoneer with a 327 Vigilante. When I bought her she had a modern air cleaner assembly on top of a 2bbl carburetor - carb was an old Motorcraft 2bbl mounted on a Ford spacer plate. Sucked air through the gaskets because it wasn't shaped right. What I thought was the original air cleaner assembly (oil bath type) was in the floor of the vehicle, but I never looked at it carefully until now.
It appears to be for a single barrel carburetor - at least the hole seems about that size (smaller than for a 2bbl).
It is the original "rampart red" color with the flat, ribbed air intake tube. Looks just like what I see in pictures of the 327 Vigilante's original air cleaner.
Does anyone have a 2bbl assembly for sale? Or better yet, is there a way to convert what I have to the 2bbl?
Thank you.
John Small
1965 Kaiser Wagoneer
AMC Vigilante 327 V8
Paint 229
Trim 186
Old 10-20-2020, 12:54 PM
Cliff's Avatar
Cliff Cliff is offline
John - although not 100% sure I think that would have had a Carter 2-barrel but I don't know the model number. This carb (as well as the Rochester Dualjet) has a small throat when compared to the Autolite/Motorcraft. Is it possible your air cleaner is for a smaller 2-barrel?
Cliff Danley
1977 Cherokee S
Old 10-22-2020, 12:28 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
The AMC 327's with a Carter 2bbl had a small opening on the top of the carb, much smaller than the later model Motorcraft carbs. I wanted to replace my 2210 with a more modern carb but decided not to due to the air cleaner issue. I even decided against modifying the air cleaner housing to accept a paper cartridge filter out of concern that I wouldn't be able to find an element to fit.
The good news is that these air cleaners work well and aren't too much trouble!
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Which air cleaner should I use? Blake General FSJ Tech 19 07-19-2012 09:22 AM
Air Cleaner on 79 Wagoneer dkmcgowan General FSJ Tech 5 07-01-2012 09:07 PM
Air Cleaner Assembly replacement Q's... j20brett General FSJ Tech 9 05-24-2007 09:16 PM
Stock air cleaner upgrades J10-401 General FSJ Tech 5 12-26-2005 05:47 AM
Missing parts on my air cleaner housing...help?? jeepthing General FSJ Tech 5 01-10-2003 04:10 AM
