Old 02-04-2015, 02:18 PM
Honchov8 Honchov8 is offline
Dual snorkle air cleaner
As I recall someone had restored a FSJ a few years ago and used a 1966-67 Olds Toranado air cleaner with the dual snorkels. The thread had a bunch of photos and the air cleaner looked awesome on the Jeep. I'm considering doing the same air cleaner set-up. I searched the archives but I couldn't find the write up. Does anyone remember seeing this thread and who may have done the restoration?
1976 J10 Honcho "Z" code
Old 02-04-2015, 02:55 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
Is this what you are looking for Scott? http://www.ifsja.org/forums/vb/showthread.php?t=139185
Page 2 has the air cleaner. Frank is running the matching Olds engine though.
Originally posted by Ristow
i bet it was Simon....
Old 02-04-2015, 03:01 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Abort? Retry? Ignore? >
Old 02-04-2015, 05:55 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
www.ramairbox.com
-99 XJ Limited.
Old 02-04-2015, 06:21 PM
Simon,
That's the one I was looking for. Could you use the same air cleaner on an AMC V8 without any clearance issues? Thoughts....
Thanks, Scott
Old 02-04-2015, 09:37 PM
addicted's Avatar
Big Meanie
As long as there is hood clearance or you don't mind chopping one up a little to create enough, I don't see why not. I had a nice Mopar dual snorkle from an early mid 70's car that would have worked with a little trimming of the base. Not as nice as the Olds cleaner Frank has but it looked good under the hood sitting on top of the 360.
Old 02-04-2015, 10:04 PM
DieselSJ's Avatar
Originally Posted by Honchov8
Simon,
Thanks, Scott
While maybe not as cool as an old school original, the ones on the link I posted will fit any standard flange carb. They also have different rise and drop bases so you can get whatever fits. Plus they have all the plumbing and pieces to get cold air from behind the grill.
-99 XJ Limited.
Old 02-07-2015, 11:00 AM
Tinkerjeep's Avatar
Banned
Originally Posted by Tripwire
I've done this too, just add a snorkel. His looks nicer than mine. I've run it on a couple of rigs; shown here on top of the throw-away360 in my green truck. but currently its on my 1981 Cherokee 360 4barrel.
But the green truck eventually got this:
Dual snorkle air cleaner red mistress General FSJ Discussion 38 02-01-2019 09:04 PM
Air Cleaner on 79 Wagoneer dkmcgowan General FSJ Tech 5 07-01-2012 09:07 PM
Eternal intake swap! Edbrk Air Cleaner doesn't fit Edlbrk CARB. j2sax General FSJ Tech 2 12-30-2011 02:59 PM
