Thread Tools Display Modes
Old 07-19-2000, 12:21 PM
RUDY RUDY is offline
Unhappy
just got my gw back from machine shop after the complete rebuild.....all is well except for the starter dragging....mech says its old and no big deal he just doesnt do starters.....anyway got it home it sat 2-3hours .went to pull it into garage and she wont start....got power but when you turn key nothing happens .please help..thanks in advance.
EMAIL FISH4RUDY@MSN.COM
1988 GRAND WAGONEER
Old 07-19-2000, 12:54 PM
Shane Shane is offline
Wink
It sounds like your starter has a dead spot or is grounding out. If it is grounding out it can be fixed with a new set of bushings. If the armature has a dead spot it is probably cheeper to get a rebuilt.
Try taping on the starter a few times with a hammer, then get in and it might start.
Good luck
1982 J10 Model 25
My Daily driver since
1988
Old 07-19-2000, 02:31 PM
Ralph's Avatar
Ralph Ralph is offline
Third Member
Wink
Also make sure the green wire from the fusible link is in good shape. Engine heat causes this relatively thin wire to corrode more quickly.
Old 07-20-2000, 02:11 AM
scotty's Avatar
scotty scotty is offline
Wink
i just want to know what kind of mechanic rebuilds engines,but "doesnt do starters"?
scott
85 grand wagoneer
258/904/twin stick dana 300/dana 44/amc 20
38x15.5 gumbo mudders
snorkel/dual batteries/onboard air/"custom" convertable
3 inch body lift/mostly stock suspension/"modified" fender openings
custom front/rear bumpers and brushgaurd
Old 07-20-2000, 03:18 AM
BobBarry
Posts: n/a
Wink
<BLOCKQUOTE>quote:</font><HR>Originally posted by scotty:
<HR></BLOCKQUOTE>
Well, you know how some body-shops call in a glass-shop to pull and install windshields?
That must be what this guy does: He unbolts everything from the engine, calls a guy to come in and undo the two bolts and two wires to the starter (it's an '88 with a Mitsu starter, so the wiring is twice as complicated), then unbolts everything else, machines and mic's the engine internals, torques everything to spec, bolts the engine back in, calls his starter guy again for the two bolts and two wires, and then finishes reinstalling the engine himself...
Seriously, though, if he rebuilt the engine, he had the starter sitting there on the bench the whole time. He sure could order a $70 replacement and do what he did when he R&R'd it for the rebuild. But then again, if you're patient, you could do it yourself.
Bob Barry<UL TYPE=SQUARE>* '78 Cherokee 4-door
* '88 Grand Wagoneer[/list]http://studentweb.providence.edu/~rbarry/wheels/
Old 07-20-2000, 05:29 AM
ClarkGriswald's Avatar
ClarkGriswald ClarkGriswald is offline
Wink
Heheheh cant help it thats kinda funny..
Do ya think mabye all those maids that say "I dont do windows" are actually really good at putting starters on FSJ's? hmmm
88 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229 (Funky)
Bone Stock (for now)
NO RUNNING BOARDS!
Old 07-20-2000, 06:06 AM
Snakeyes_Tx Snakeyes_Tx is offline
Wink
Have you tried tapping on the shifter to make sure its fully engaged in park? Or try starting it in neutral? After dropping my new motor in and putting the tranny linkage back together the tranny shifter was alot smoother and well, it felt kinda loose, but now it is a little harder to get it to click over the *Neutral-start switch* That may be your problem right there... try starting in neutral and see what happens.
I can't believe none of you other guys thought of this! Shame on yall!
Old 07-20-2000, 06:12 AM
Wink
I forgot to mention to always check the basics like battery, fusible links, neutral safety switch, etc.
Shane
1982 J10 Model 25
1988
Thread Tools
